Old 12-Jan-2013, 4:41 AM   #3
Above the roof in such a manner that the roof and house are not blocking reception to the north east install a Winegard HD7082P antenna aimed at about 60 degree magnetic compass direction.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/ychim.html , http://www.ronard.com/34424560.html if using a eave mount use the #4560. , http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
____________
Install a Antennas Direct CPA-19 preamp.
____________
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
__________
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7082P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Some Digital Tv/s will automatic channel scan for cable Tv channels.
Go into the Tv setup menu and select , 'Air Channels' / 'Antenna Channels'.
