KTFK-DT , K14MW-D , KTVJ , have applications to transmit on the VHF low band channels 2 thru 6.
The HD7000R is a Small All channel antenna that receives ,
UHF band channels 14 thru 51.
Buy a All channel antenna now or buy one later , it is your choice.
The cost of the HD7000R antenna is less then a antenna that is designed for channels 7 thru 51.
Here is a antenna that is designed to receive channels 7 thru 51 , the ANT751.
