Old 11-Jan-2013, 7:51 PM   #2
elmo
I think you'd be fine with a small UHF/VHF antenna like the ANT-751, since you're only 25 miles from most with good LOS. Of course, that doesn't take into account trees, buildings, etc. Mount it on the roof and point it due east and set your tv to scan for antenna signals. It should find a few by the looks of your plot. Scan with a direct connection to one TV, then once you have em programmed in, switch the connection to the other and do the same. Check some signal strengths for certain channels on each tv, typically done at a setup screen on the tv. Note them and then connect both using the splitter. Now compare signals on each to your notes. If they're still good, skip the amp. If they're weak or you've lost some, then you can add an amp at the split.
