Old 10-Jan-2013, 2:12 AM   #4
Above the roof in such a manner that the roof or house are not blocking reception in the directions of , south , south east , north east , install a Winegard HD7696P antenna with a Antennas Direct CPA-19 preamp aimed at about 70 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes.com/antenna/pointing.html.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/ychim.html , http://www.ronard.com/34424560.html if using a eave mount use the #4560 . , http://www.ronard.com.
___________
Buy the HFS splitters at , http://www.solidsignal.com or http://www.hollandelectronics.com.
___________
These Digital TV stations should be received.
WZME Real UHF Digital channel 42 , virtual number (x) Me-Tv and IND. and RTV.
WEDW REAL UHF Digital channel 49 , virtual number (x) PBS.
WTNH-DT REAL VHF Digital channel 10 , virtual number (8.1) ABC.
WCCT-TV REAL UHF Digital channel 20 , virtual number (x) The CW and This Tv.
WVIT-DT REAL UHF Digital channel 35 , virtual number (30.1-2) NBC and COZi Tv.
WFSB REAL UHF Digital channel 33 , virtual number (x) CBS.
WTIC-TV REAL UHF Digital channel 31 , virtual number (61.1) FOX and Antenna Tv.
WEDH-DT REAL UHF Digital channel 45 , virtual number (x) PBS.
WFTY-DT REAL UHF Digital channel 23 , virtual number (x) Tel.
WCTX-DT REAL UHF Digital channel 39 , virtual number (59.1) MyNetwork.
WUVN-DT REAL UHF Digital channel 46 , virtual number (18.1) Univision.
WTNH , WCTX , WZME , WEDW , will be received at front angles and back angles to the HD7696P antenna.
________________
As always , trees and tree leaves do a real good job of , reflecting , reducing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to locate the HD7696P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan For the Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Go into the Tv setup menu and select , 'Air Channels' / 'Antenna Channels'.
Digital tuners can develop - Digital Glitches - that are not cleared out with a simple channel scan.
Do a Double Channels scan.
_______________________________________
The antenna system Must Not be connected to any live pay cable service such as and not limited to , pay cable tv , pay cable internet , pay cable phone.
If you are continuing with pay cable internet , the pay cable internet must be on a Separate coax that is not part of the antenna system.
Yes the coaxes that are in or on the house can be used for the antenna system. However No active pay cable services can be on the the coaxes that are used for the antenna system.
You can find out and label the coax wires buy using the antenna as a Test signal.
Use a small or large Digital Tv , connect the antenna coax to a coax , and then go around with the Tv to find the other end of the coax and the label the coax at the starting place where the antenna coax is connected.
