Old 8-Jan-2013, 10:43 PM   #7
No Responce.
Well any way ,
For reception of at 25 feet antenna height.
__________________________________________
Antenna system #1.
K38AK-D REAL UHF Digital channel 38 , virtual number (x) PBS.
KTEW-LD REAL UHF Digital channel 18 , virtual number (x) RTV Retro Tv Network.
K35JY-D REAL UHF Digital channel 35 , virtual number (x) RTV.
KXOK-LD REAL UHF Digital channel 31 , virtual number (x) AM1 America One.
K45EJ REAL UHF Digital channel 44 , virtual number (45.1-2) MyNetwork and This Tv.
KOCO-TV REAL VHF Digital channel 07 , virtual number (5.1) ABC.
Aim a Winegard HD7696P antenna with a Antennas Direct CPA-19 preamp at about 215 degree magnetic compass direction.
______________________________________________________
Antenna system #2.
KDOR-DT REAL UHF Digital channel 17 , virtual number (17.1) IND.
KOED-TV REAL VHF Digital channel 11 , virtual number (x) PBS.
KJRH-DT REAL VHF Digital channel 08 , virtual number (2.1) NBC.
KOTV-DM/DT REAL UHF Digital channel 45 , virtual number (6.1) CBS and CW.
KOKI-DT REAL UHF Digital channel 22 , virtual number (23.1) FOX.
Aim a Winegard HD7698P antenna with a Antennas Direct CPA-19 preamp at about 121 degree magnetic compass direction.
Separate the 2 antennas by about 3 feet.
Antenna systems #1 and #2 are Not connected together on to one coax.
The 2 antenna systems are Separate all the way to the location/s of the Tv/s.
Separate antennas , separate preamps , separate splitter , separate coaxes.
_______________________________________________________________
For 1 Tv connected use no splitters.
The separate antenna systems will connect to a Remote control A/B antenna switch at the Tv location , http://www.mcmelectronics.com #32-4425 .
Buy the HFS splitters at , or , http://www.hollandelectronics.comhttp://www.solidsignal.com.
For separate antenna systems , every thing is doubled.
As always , trees and tree leaves do a rel good job of , reflecting , reducing , blocking , Digital Tv reception and so do buildings and other obstructions.
It is best install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv's Must Channel Scan for the Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Go into the Tv setup menu and select 'Air Channels' or 'Antenna Channels' .
The 2 antenna system is Channel Surfing Friendly , press the button on the Hand held remote control , Change Antennas And Keep On Channel Surfing.
Using a antenna rotator and 1 antenna Is Not channel surfing friendly , must wait for antenna to rotate and there will be domestic issues about where the antenna is aimed.
