If the attic is your only option, go for it. I would start by measuring... how long an antenna can you accommodate? How wide?
You'll certainly get many signals, but how each is affected by the antenna location is only going to be known once the antenna is installed.
You mention Channel Master... If it would fit, the CM-3671 is not overkill in an attic.
If you're fighting reflections (AKA multipath) or weak signal levels, a big directional antenna is the first and best tool to use.
