Antenna and set-up
Though I understand the previous threads, I think I am stuck with an attic install. The attic is large and has high ceilings, allowing me to get about 25' above the ground. The roof is shingled with wood frame construction.
Can you recommend an antenna? I have been looking on Channel Master but am unsure as to how "much" antenna I need, if I need a rotor, amplifier, etc. Will I need multiple antennas or additional hardware to maximize potential reception?
I would guess from elmo's post that I would aim the antenna at 253 degrees. Will this pick up both Philly and NY stations?
Thanks for your guidance.
Regards,
-J
