In an ideal world, you would be able to use an outdoor antenna with an unobstructed view to the east. Your TVFR indicates a mid to large size antenna (Winegard HD7694P or HD7696P) would do well if pointed between east and north east.
However, if you're limited to using an indoor antenna, the HDTVi will do best if it has a view to the east.
Can you mount an RCA ANT-751 on your balcony and get a view to the east?
