Old 7-Jan-2013, 10:29 PM   #12
------>NO Antenna Rotator<------
Now you are in the Testing phase of reception.
The main part but not the only part of the test is to see if WYFF NBC is receivable.
Thats why the tripod stand , so as to move the antenna around and up and down to find a hot spot for reception of WYFF.
If WYFF is receivable then I recommend a Channel Master CM4228HD antenna for reception of WYFF with a Antennas Direct CPA-19 preamp.
The HD7698P antenna and CPA-19 preamp system.
And the CM4228HD antenna and CPA-19 preamp system.
Are Separate antenna systems.
And Will Not be connected on to one coax.
The 2 antenna systems will have every thing separate , Separtate antennas , separate preamplifiers , separate splitters , separate coaxes , all the way to the location/s of the Tv/s.
_____________________________________________________
Use no splitter if 1 Tv is connected.
Then for 2 Tv's connected use a , HFS-2D , 2 way splitter.
3 Tv's connected use a , HFS-3D , 3 way splitter.
Buy the HFS splitters at ,http://www.solidsignal.com , http://www.hollandelectronics.com.
The -->Separate<-- antenna systems will have Separate splitters.
If more then 1 Tv is to be connected then use a ,
HFS-2D , splitter for 2 Tv's connected.
HFS-3D , splitter for 3 Tv's connected.
For each system.
Another way to understand is -->Double every thing for 2 separate systems.
A Remote control A/B antenna switch will be at each Tv location to switch from one antenna system to the other.
http://www.mcmelectronics.com #32-4425 .
A/B antenna switching is Channel Surfing Friendly , press the button on the hand held remote control , change antennas and Keep On Channel Surfing.
For Now with the 1 HD7698P antenna and CPA-19 preamp , You are in the testing phase.
Only have 1 Tv connected for the Testing phase.
Tv antenna rotators Are Not channel surfing frinndly , must wait for antenna to rotate and there will be domestic conflict about the direction the antenna is pointed.
When aiming/testing for reception of WYFF , I recommend do a Double Channel Rescan because Digital tuners can develop - Digital Glitches - that simple channel scans do not clear out of the Digital tuner.
WYFF will most likely not be easy to receive so with a double channel rescan the Digital tuner will be cleared out for a good lock on UHF channel 36 WYFF.
