Thread: Channel 7 Woes
Old 7-Jan-2013, 6:46 PM   #4
The first situation that comes to mind is multipath.
________________________________________________
The next situations are interference isuses.
Unplug , disconnect , switch off , every thing in the house One At A Time to see if something is generating interference.
The first suspects are , floresent lights of all types and kinds , computers of all types and kinds , radios of all types and kinds , Unplug transformers from electrical outlets and keep on , unpluging , disconnecting , switching off every thing.
Most electronics are powered buy transformers and even if the unit is powered down to some degree it is still active and ready to power back up , so unplug it.
Even washers and dryers and stoves and do not forget the sprinkler system power. The name of the game is shut it down completely. Even some ceiling fans are powered up even when switched off. And what about those smoke detectors?
The point is , shut it down!
Switch off the circuit breakers in the circuit breaker in the circuit breaker box.
And also can switch off the Main Circuit Breaker that shuts every thing off.
And use a battery powered Tv.
And the Directional HD7694P antenna can be used as a interference finder with a loooooong coax so as to move the antenna around and point the antenna all around to find a interference source , and even the neighbors house can be investegated to some degree from the outside using the antenna as a interference finder.
And I even found the the Tv its self was generating its own interference.
