Old 7-Jan-2013, 3:22 PM   #2
elmo
IMO, you want an antenna that can get VHF too for those channels like real 9 & 10; the DB4e is basically UHF only. I'd check into a Winegard HD7696p or similar instead. You'll want to aim it at 221 deg.
The quad RG-6 sounds like overkill unless you have a spool in the garage already. I don't think quad will help with signal loss as the core is the same; it just offers better resistance to interference. But it can't hurt if you really want that.
You may need a pre-amp but you can wait to see how it goes w/o it, as they're easy enough to add afterwards.
