Old 7-Jan-2013, 2:29 PM   #12
elmo
Originally Posted by nightshark View Post
All of the sudden I am unable to receive the fox station kbss-dt, 31-1. Any ideas what might be going on? I checked the antenna's position and it's the only station I have lost.
http://www.tvfool.com/?option=com_wr...c84fe12930a2fd
Can you double check the station? I don't see a KBSS nor 31.1. I'd assume KMSS 33.1 is it?
Any chance you noted signal strength prior to it dropping? Are you getting any amt of signal now - checked on the TV's signal meter? What direction is the antenna pointed?
If it was borderline, atmospheric changes like weather can affect it.
