Old 6-Jan-2013, 4:11 PM   #5
Originally Posted by Mason View Post
Thanks .. and can you please tell me which additional cables I should get as it's not clear what comes with this antenna. Is it coax out and do I need something that is coax to HDMI? I'm quite new to all this ..
The HDTVi will have a cable, long enough to set the antenna on or near the TV.
If the TV was built after March of 2007, it should have an over-the-air capable digital tuner. In that case simply connect to the 'ANT' or 'ANTENNA' connector on the TV.
As teleview already mentioned, you'll need to set the TV tuner to use 'Air' or 'Antenna' mode, not 'cable'. Then run a new channel scan.
