The Terk HDTVi (not HDTVa) is the first thought that pops to mind.
Your report indicates many strong signals so you'll want to avoid any sort of amplified antenna.
Indoor reception can be challenging if the signal has to travel through walls or other obstructions. The best location for any antenna is one which provides a clear line of sight to the transmitting antenna.
