Yes it's a panel antenna. You need RG6 coaxial cable. Quad shield usually isn't necessary, the regular stuff is ok. Home Depot, Lowes etc will have this wire, connectors, connector installation tools, splitters, grounding blocks. I like compression style connectors. Get some silicone grease for any outdoor connections. If you need additional rubber weather boots a sparkplug boot works pretty good.
