Old 4-Jan-2013, 10:43 PM   #5
Many , many , many , many , many , many , Digital Tv stations/channels will be received.
Install a Winegard HD7084P antenna aimed at about 272 degree magnetic compass direction.
Here are some strong and sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
___________
For 1 Tv connected use no splitter and no preamplifier.
For 2 or more Tv's connected use a Antennas Direct CPA-19 preamp.
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
__________
Trees and tree leaves do a real fine job of reducing or blocking Digital Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7084P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
At your location the directions of reception are , west , north , north east , east.
__________
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Some Tv's will automatic channel scan for cable tv channels.
In the Tv menu select the 'Air Channels'/'Antenna Channels' to scan for channels.
DO NOT Channel Scan For Cable Tv Channels.
