Coax cable is -->Always<--> Suspect of being bad.
Every time a spitter split takes place the signal strength is reduced.
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
Concrete roof tiles and stucko Wire do a real fine job of reducing or blocking Tv reception.
Tv antennas are what receive the Tv transmissions.
Amplifiers are not Tv antennas and are not a substitute for a Tv antenna.
The Tv antenna -->needs<-- to be at a location that receives the best signal.
The Federal Antenna Law was written so that you and others do not have to hide antennas.
HOA's and others can not beat on you and make you hide antennas.
