Conditions certainly get better as you increase the antenna mounting height. Feel free to experiment with high AGL values if you think you can mount higher than 25'.
If 25' AGL is the highest practical mounting for you, consider a Winegard HD7698P or HD7084P pointed toward NYC. You can expect the strong signals from the opposite direction to be received also. If you are going to drive a splitter, you'll want to also install an Antennas Direct CPA-19 preamp close to the antenna. If you can't find a CPA-19, the Winegard HDP-269 would be another option.
