Old 2-Jan-2013, 12:43 AM   #9
tlhfirelion
Originally Posted by elmo View Post
A compass is a good start. Use your plot and table as your guide as it has all the locations on there. You will want to tweak it a degree or two to find the best signal for you. Your TV likely has a signal meter built in. Have it rescan for channels once attached. Be sure and check all channels for signal strength before you clamp it down.
As for distance ratings, I doubt there's a standard. Larger antennas are more directional so they can pull from a greater distance. Smaller antennas pull in a wider range of stations from various directions as long as they aren't far away. Think of it as a spot light vs a flood light. There's no hard cut off, reception fades the further away you are, that's all.
That makes sense. Thank you.
tlhfirelion is offline   Reply With Quote
