Old 2-Jan-2013, 12:41 AM   #7
tlhfirelion
Originally Posted by teleview View Post
Above the roof in such a manner that the roof and house does not block reception to the , north - north east and south east.
Install a Winegard HD7696P antenna with a Antennas Direct CPA-19 preamp aimed at about 10 degree magnetic compass direction.
Here is how to aim antenna , http://www.kyes.com/antenna/pointing/pointing.html.
Buy the HFS splitters at , http://www.solidsignal.com or http://www.hollandelectronics.com.
______________________________________________
For now as a test of reception I recommend run a separate coax from the antenna/preamp to one Tv.
Or can disconnect a coax from the satellite system and use that coax.
For the reception of ,
K25BD REAL Digital UHF channel 25 , virtual number (25.1) Religion.
KBNS-CD REAL UHF Digital channel 36 , virtual number (x) The Vacation Channel.
KSPR-DT REAL UHF Digital Channel 19 , virtual number (x) ABC and CW.
KYTV REAL UHF Digital channel 44 , virtual number (3.1-2) NBC and Local Weather.
KOLR REAL VHF Digital channel 10 , virtual number (10.1) CBS.
KOZL-Tv REAL UHF Digital channel 28 , virtual number (27.1) Independent Tv station.
K17DL-D REAL UHF Digital channel 17 , virtual number (x) Branson Vistor Channel.
KOZK-DT REAL UHF Digital channel 23 , virtual number (21.1-2-3) PBS and Educational Telecourses and Create.
KRBK REAL UHF Digital channel 49 , virtual number (49.1-2) FOX and MyNetwork.
K21JS REAL UHF Digital channel 21 , virtual number (21.1) Religion.
And
KTKO-LP REAL VHF Digital channel 08 , virtual number (8.1-2-3) ION and Qubo and ION Life.
Are both Strong transmissions and will be received through the back angle of the HD7696P antenna.
K26GS-D REAL UHF Digital channel 26 , virtual number (26.1-2-3-4) Retro Tv Network and Antenna Tv and THIS Tv and Me-Tv.
Is weaker signal strength , however I think it will be received through the back angle of the HD7696P antenna , may require some aim adjustment of the HD7696P antenna.
As always , trees and tree leaves do a real fine job of reducing or blocking Digital Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7696P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
Install the HD7696P antenna Up High.
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html[/URL] , http://www.ronard.com/ychim.html , http://www.ronard.com , http://www.ronard.com/34424560.html , if using the eave mount use the #4560.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , often nemed the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel trhrough the air from the transmitting antenna to the receiving antenna.
Teleview, thanks for your reply. For some reason I was never notified via email of your reply and didn't get it until this evening. I appreciate the detailed information. I'll admit I'm confused about which direction to go here, winegard HD7696P or Clearstream 2V. The clearstream is more appealing from a mounting and cosmetic standpoint. It will mount to the side or in front of the high temperature stove pipe we have exiting the top of the chimney much easier. As can sometimes happen, I don't know which advice to follow because they both seem right to me.
tlhfirelion is offline   Reply With Quote
