Old 2-Jan-2013, 12:22 AM   #4
To receive the receivable Digital Broadcast Tv stations/channels , one aim direction will do it.
NBC , ABC , CBS , PBS and other PBS channels , FOX , MyNetwork , CW , RTV , Me-Tv , This Tv.
Above the roof in such a manner that the roof and house do not block reception to the , south east , south west , north west.
Install a Winegard HD7084P antenna at about 25 feet above ground (higher is better) aimed at about 141 degree magnetic compass direction.
_____________________________________________________________
(Your location has receivable Tv stations/channels in ALL 3 Tv channel bands of ,
UHF band channels 14 thru 51.
The HD7084P antenna is designed to receive ALL 3 channel bands.)
______________________________________________________________
Try reception without a preamp.
KNBN NBC , KBHE PBS , KCLO CBS , are weak signal strength.
The HD7084P antenna receives more signal because it has more and longer metal receiving elements , so this makes the reception much stronger.
If there are some reception issues with weak signal strength tv stations (I do not think there will be any issues) , then install a Antennas Direct CPA-19 preamplifier.
For 1 Tv connected with the preamplifier , use no splitter.
For 2 Tv's connected with the preamplifier , use a , HFS-2D 2 way splitter.
Buy HFS splitters at , http://www.solidsignal.com or http://www.hollandelectronics.com.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/Tripods%200703/4712.html , http://www.ronard.com/34424560.html if using the eve mount use the #4560 , http://www.ronard.com/ychim.html , http://www.ronard.com.
As always , trees and tree leaves do a real fine job of reducing or blocking Digital Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7084P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Digital Tv tuners can develop - Digital Glitches - that are not cleared out with a simple channel scan.
Do a Double Channel scan , http://www.dtv.gov/rescan.html.
And also , http://transsistion.fcc.gov/cgb/cons...cts/rescan.pdf.
_______________________________________________________________________
-------------->DO NOT Channel Scan For Cable Tv Channels.<-----------------
