Old 31-Dec-2012, 6:53 PM   #8
ny1329
More follow-up
So I moved my older TV to the newer TV's location. When I did a channel search, there was no change in the channels that it could pull in. So I am assuming the TV is the issue.
For the missing stations, any ideas on why I could get the other stations during one of my antenna moves, but then I can't at my present location?
I am assuming the signal is weak because my antenna is in the attic and that is why my thoughts on a pre-amp (I was thinking pre-amp and not an amp as stated in my earlier post).
Suggestions on another antenna? Would the HD7694P make much of a difference?
Anyway, thanks again.
Kurt
ny1329 is offline   Reply With Quote
