Old 31-Dec-2012, 2:27 AM   #4
tlhfirelion
Originally Posted by elmo View Post
I'd avoid the omni directional antennas. You want those signals from the N-NE direction; why not aim at them for the best reception.
You have issues getting Ch 10 because it's a VHF channel and your antenna is probably not the best for VHF.
Make sure the antenna you choose is UHF & VHF. If you want to go with a small arrow, try the ANT-751, but you may be pushing it's range. A Winegard HD7694p would be better and it's not too big, IMO. If you want something less arrow-like, I'd check out the Clearstream 2-V.
Don't bother with an amp now - you can add it later if needed. It's probably fine if only feeding one TV.
The existing coax is fine to use, as long as the antenna is the only thing using it; antennas don't mix well with sat/cable/internet.
Elmo, thanks for the helpful reply. I looked over the antenna suggestions you posted and the 2V looks like a better option for us. When I do begin to install this, is th ebest way to break out my trusty compass and aim for the middle of the cluster on my FOOL report N-NE?
I notice a lot of the antenna today say 50+miles or 60+ miles, what that mean exactly? Does the signal drop like a stone after 51 miles? Do I need to get something stronger then what I need? If so, I'm OK with overkill. lol
If we ever do add a TV to the Master bedroom I'll see how the signal strength is before getting any signal booster device. it's only a run of about
8' so I can't imagine the signal is that far gone.
Regarding your concern about the internet interfering with the TV signal, its' thru our phone lines and nowhere near this part of the house so it's should be an issue.
Thank you for the help and if anyone else has any feedback it's appreciated!
tlhfirelion is offline   Reply With Quote
