Old 30-Dec-2012, 10:18 PM   #2
elmo
I'd avoid the omni directional antennas. You want those signals from the N-NE direction; why not aim at them for the best reception.
You have issues getting Ch 10 because it's a VHF channel and your antenna is probably not the best for VHF.
Make sure the antenna you choose is UHF & VHF. If you want to go with a small arrow, try the ANT-751, but you may be pushing it's range. A Winegard HD7694p would be better and it's not too big, IMO. If you want something less arrow-like, I'd check out the Clearstream 2-V.
Don't bother with an amp now - you can add it later if needed. It's probably fine if only feeding one TV.
The existing coax is fine to use, as long as the antenna is the only thing using it; antennas don't mix well with sat/cable/internet.
