Old 29-Dec-2012, 10:41 PM   #2
A Simple reception situation.
Most of the stronger easier to receive Digital Tv stations transmissions are the Greenville area.
Here are the Digital Tv stations/channels that should be received.
WHNS REAL UHF Digital channel 21 , virtual number (21.1) Fox.
WUGA-TV REAL UHF Digital channel 24 , virtual number (x) PBS.
WMYA-DT REAL UHF Digital channel 14 , virtual number (4.1-2) MyNetwork and The Country Network.
WYFF-DT REAL UHF Digital channel 36 , virtual number (4.1-2) NBC and This Tv.
W11DD-D REL VHF Digital channel 11 , virtual number (x) PBS.
WNTV REAL VHF Digital channel 09 , virtual number (29.1) PBS.
WGGS-TV REAL UHF Digital channel 16 , virtual number (16.1) Religion.
WYCW-DT REAL UHF Digital channel 45 , virtual number (62.1) The CW and CBS.
WSPA-TV REAL VHF Digital channel 07 , virtual number (7.1-2) CBS and Me-Tv.
WNEH-DT REAL UHF Digital channel 18 , virtual number (38.1) PBS.
WLOS REAL VHF Digital channel 13 , virtual number (13.1-2) ABC and MyNetwork.
Above the roof in such a manner the reception is not blocked buy the roof or house in the directions of , north , north east , east , west , install a Winegard HD7696P antenna with a Antennas Direct CPA-19 preamp aimed at about 36 degree magnetic compass direction.
As always , the starting aim direction of the antenna is the --> starting aim direction of the antenna.
The antenna can be , turned , moved up and down or relocated , to find the best reception.
Most Digital Tv's have a signal strength meter and some Digital Tv's also have a signal quality meter.
___________________
For 3 Tv's connected use a HFS-3D , 3 way splitter.
Buy the HFS splitters at , http://www.solidsignal.com or http://www.hollandelectronics.com.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
____________________
As always trees and tree leaves do a real fine job of reducing or blocking Digital Tv reception and so do buildings and other obstructions including your own house.
It is best to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
___
