Old 29-Dec-2012, 2:17 AM   #3
No Response.
Well any way , at the 40 feet antenna height.
Install a WINEGARD HD7698P antenna with a Antennas Direct CPA-19 preamp , aimed at about 90 degree magnetic compass direction.
For the reception of ,
WLOS REAL VHF channel 13 , virtual number (13.1-2) ABC and MyNetwork.
WUNF-TV REAL UHF channel 25 , virtual number (33.1-2-3) PBS.
WASV-LP REAL UHF channel 50 , virtual number (50.1-2) , WYCW-DT The CW and , WSPA-TV CBS.
W34DX-D REAL UHF channel 34 , virtual number (21.1) WHNS FOX.
W41BQ REAL UHF channel 22 , virtual number (41.1) 3ABN.
W08BP-D REAL VHF channel number 08 , virtual number (7.1-2) CBS and Me-Tv.
Install the HD7698P antenna at a location that is Away From the Trees to the , north east , east , south east.
Do not underestimate the - Desire Of Trees - to reduce or block Digital Tv reception.
Keep the HD7698P antenna Away From The Trees of the directions of reception.
Tv antennas like a Clear View of the transmitting antennas.
_________________________________
As a Test of reception , aim the HD7698P antenna with the CPA-19 preamp at about 152 degree magnetic compass direction for the reception of ,
WYFF-DT REAL UHF channel 36 , virtual number (4.1-2) NBC and This Tv.
http://en.wikipedia.org/wiki/WYFF.
Rescan scan for Digital Broadcast Tv channels.
Digital Tv tuners can develop - Digital Glitches - that are not cleared out with a simple channel scan.
Might help to do a Double Channel scan.
http://www.dtv.gov/rescan.html.
And also.
http://transition.fcc.gov/cgb/consumerfacts/rescan.pdf.
During the setup and testing phase have only 1 Tv connected , No splitters.
As always the starting aim direction is --> the starting aim direction.
The antenna can be turned and moved up and down and the location can be changed for best reception.
Most Digital Tv's have a signal strength meter and some Digital Tv's also have a signal quality meter.
As always , trees and tree leaves do a real fine job of reducing or blocking Digital Broadcast Tv reception and so do buildings and other obstructions including your own house.
It is best to install the Tv antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
The Digital Tv Must Channel Scan for the Digital Broadcast Tv channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Here are some above the roof antenna mounts , http://www.ronard.com/ychim.html , http://www.ronard.com/34424560.html if using the eave mount use the #4560 ,
http://www.ronard.com/909911.html ,
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
