Old 27-Dec-2012, 8:54 AM   #7
Most of the Digital Broadcast Tv stations/channels at your location are less then 3 miles away and are - Over the Top Strong Signal Strength - at your location.
The Tv transmissions are so over the top strong that the first 12 of the tvfool channel list are high lighted Red.
DO NOT use any type or kind of amplified antenna or preamp or distribution amplifier , non , zip , zero and zilch.
The amplifier Will Over Load and be the cause bad or no reception of some channels.
_____________________
Above the roof in such a manner that roof or house are not blocking reception in the directions of , north , south west , south , south east.
Install a Antennas Direct Clear Stream 2 Complete VHF/UHF antenna aimed at about 150 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes.com/antenna/pointing.html.
Remove the Reflector Screen from the CS2V Complete and the CS2V Complete will receive Broadcast Tv stations/channels at front and back of the antenna , the Digital Broadcast Tv stations are to the , north , south west , south , south east.
http://www.antennasdirect.com/store/...VHF-Combo.html.
Here is a variable attenuator to reduce the over the top signal strength , if required , #1296F.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com.
_________________________________________________
For 1 Tv connected use no splitter. No amplifier.
For 2 Tv's connected use a common simple 2 way splitter. No amplifier.
For 3 Tv's connected use a common simple 3 way splitter. No amplifier.
_________________
As always , trees and tree leaves do a real fine job of Reducing or Blocking Digital Broadcast Tv Reception and so do buildings and other obstructions including your own house.
It is best to install the CS2V Complete antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions including your own house.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , if using the eave antenna mount then use the #4560. , http://www.ronard.com/ychim.html , http://www.ronard.com.
The Tv's Must Channel Scan for the Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Broadcast Tv transmissions travel through the air to the transmitting antenna to the receiving antenna.
