At 40 feet antenna height , WYFF-DT REAL UHF channel 36 , virtual number (4.1-2) NBC and This Tv has a signal strength of Minus -12.5 NM(dB).
This puts the signal strength on the edge of the finger tips for reception.
To see what signal strength does at other antenna heights please make 5 more tvfool radar plot reports.
1 foot antenna height.
5 feet antenna height.
Yes the antenna height requests of 1 and 5 feet are correct.
Many situations of Tv transmissions crossing over hills and mountains will - Bend - the signal closer to the ground and the signal strength will be stronger closer to the ground.
25 feet antenna height.
60 feet antenna height.
100 feet antenna height.
