Old 26-Dec-2012, 6:39 AM   #4
A Simple reception situation that requires a Big antenna.
For reception of the San Diego Digital Tv stations/channels.
Above the roof in such a manner that the roof or house is not blocking reception to the , south west , south , south east.
Install a Winegard HD7698P antenna aimed at about 136 degree magnetic compass direction.
For 1 Tv connected use no splitter. No preamp.
For 2 Tv's connected use a common simple 2 way splitter. No preamp.
__________________________________________________________________________
For reception of the L.A. Digital Tv stations/channels.
Above the roof in such a manner that the roof or house is not blocking reception to the , north west.
Install a Winegard HD7084P antenna with a Antennas Direct CPA-19 preamp aimed at about 317 degree magnetic compass direction.
For one Tv connected use no splitter.
Buy the HFS splitters at , http://www.solidsignal.com or http://www.hollandelectronics.com.
_______________________________________________________________________________
The HD7084P on the bottom and the HD7698P on top on the same mast , separate by about 3 feet.
The HD7698P antenna system and the HD7084P antenna system are Separate antenna systems and Are Not connected together on to one coax.
The 2 antennas systems are Separate All the way to the locations of the Tv/s and will be connected to a A/B remote control coax antenna switch at each location.
http://www.mcmelectronics.com # 32-4425 , or , http://www.radioshack.com #15-1968 .
A/B antenna switching is Channel Surfing Friendly , press the button on the hand held remote control , change antennas and Keep On Channel Surfing.
Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html if using a eave mount use the # 4560. , http://www.ronard.com/ychim.html , http://www.ronard.com.
Buy the ronard antenna mounts at ronard by typing the word ronard in the solidsignal search box.
__________
As always , trees and tree leaves do a real fine job of reducing or blocking Digital Tv reception and so do buildings and other obstructions including your own house.
It is best to locate the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
The Tv's Must Channel Scan for the Broadcast Tv Channels , often named to 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
