Old 22-Dec-2012, 7:27 AM   #5
Yes this is a tough one.
__________________________
To get the networks , NBC , CBS , ABC , PBS , FOX , RTV , This TV , Antenna Tv.
_________________________________________________________________
WKMA , WKMU , WKPD , are all the same PBS , http://en.wikipedia.org/wiki/Kentuck...nal_Television.
The antennas will be installed no less then 40 feet above ground , and up to 60 feet is better.
Antenna system #1.
For reception of ,
WPSD-DT UHF channel 32 , NBC and RTV and Antenna Tv.
WKPD UHF channel 41 PBS.
WKMU UHF channel 36 PBS.
Aim a Antennas Direct DB4e with a Antennas Direct CPA-19 preamp. , aimed at about 250 degree magnetic compass direction.
___________________________________________________________________________
____________________________________________________________________________
Antenna system #2. Is made up of 2 antennas.
For the reception of ,
WEHT VHF channel 7 ABC.
Install a Winegard YA1713 VHF antenna aimed at about 22 degree magnetic compass direction.
For reception of ,
WTVF UHF channel 25 CBS and This Tv.
http://en.wikipedia.org/wiki/WTVF.
WZTV-DT UHF channel 15 FOX.
Install a Channel Master CM4228HD aimed at about 136 degree magnetic compass direction.
_________
The YA1713 and CM4228HD are connected together with a UVSJ = UHF/VHF Separator/Joiner. Type the letters - uvsj - in the solidsignal search box.
The VHF connection of the UVSJ is connected to the YA1713.
The UHF connection of the UVSJ is connected to the CM4228HD.
The remaining connection of the UVSJ is connected to a CPA-19 preamp.
Antenna Systems 1 and 2 Are Not connected on to one coax.
Antenna Systems 1 and 2 are Separate systems all the way to the location of the Tv.
At the location of the Tv a Remote control A/B antenna coax switch will be connected to the separate antenna systems.
http://www.mcmelectronics.com , # 32-4425 , or , http://www.radioshack.com , #15-1968.
A/B antenna switching is Channel Surfing Friendly , press the button on the hand held remote control , change antenna systems and Keep On Channel Surfing.
_____
As always trees and tree leaves do a real fine job of reducing or blocking Digital Tv reception and so do building and other obstructions including roof and the house.
It is best to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including the roof and house.
The Tv Must channel Scan for the Digital Broadcast Tv channels , sometimes named the 'Air Channels' or ' Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
____
Here are some strong and sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/Tripods%200703/4712.html , http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.channelmasterstore.com.
Here are , free standing no guy wires , light weight aluminum , push up , towers , do all antenna installations and adjustments standing on the ground.
http://www.palcoelectronics.com/pe300.aspx.
Mount the YA1713 on the bottom , the CM4228HD in the middle , the DB4e on top.
Separate each antenna by about 2 feet.
