Try the Fm Trap to eliminate the interference.
FM traps are not used as a way to stop you from listening to the FM radio.
A FM trap is used to reduce or stop interference to Tv channels.
____________________________________________________________________________
I do not recommend antennas just because I can recommend antennas.
If you read the other question askers posts , you will understand that I actually know what I am doing.
And Yes it is true , you can install what ever antenna you choose.
_____________________________________________________________________________
W08PB , W02AG , WSPA , are all the same programing.
W02AG and WSPA , are alternatives to receiving W08PB that has the interference.
W02AG - VHF channel 02 is stronger signal strength then WSPA - VHF channel 7.
W02AG has a 1 edge path obstruction to the transmitter at 27.4 miles.
WSPA has a 2 edge path obstruction to the transmitter at 29.2 miles.
If CBS and Me-Tv programing is important , then the HD7082P antenna provides 2 more ways to get the programing.
And then there is WYCW and WYFF , the HD7082P is aimed at those 2.
As always the starting aim direction of a antenna is the --> starting aim direction of a antenna.
The HD7082P antenna aim direction can be adjusted for best reception.
Most Digital Tv's have a signal strength meter and some Digital Tv's also have a signal quality meter.
