Thanks for the quick replies, fellows.
Originally Posted by teleview
Try a FM Trap - radio shack #15-024.
Would this help with the interference I get on channel 8? It's a radio issue, not multi-path?
I recommend install a Winegard HD7082P All Channel Antenna aimed at about 196 degree magnetic compass direction.
Wow, that thing is huge. Not sure if it's the way to go, it's strong point seems to be pulling in weak Low-VHF signals. I need something that gets decent High-VHF (ch. 8,13) and can pull in a weak UHF signal (ch. 36) from 30 miles away while pulling in some strong UHF (ch. 21,25) from the same general direction.
