Old 21-Dec-2012, 7:01 PM   #3
Try a FM Trap - radio shack #15-024.
____________________________________________
I recommend install a Winegard HD7082P All Channel Antenna aimed at about 196 degree magnetic compass direction.
All of the current Tv channels are ,
UHF band channels 14 thru 51.
As always , the starting aim direction of a antenna is --> the starting aim direction.
The antenna can be adjusted/aimed for best reception.
Most Digital Tv's have a signal strength meter and some have a signal quality meter.
For reception of ,
WLOS - VHF channel 13 , ABC and MyNetwork.
WHNS - UHF channel 21 , Fox.
WUNF - UHF channel 25 , PBS.
W08PB-D - VHF channel 08 , CBS and Me-Tv - Repeater of WSPA-TV.
WYCW-DT - UHF channel 45 , CW and (CBS - WSPA).
W02AG-D - VHF channel 02 , CBS and Me-Tv - Repeater of WSPA-TV.
WYFF-DT - UHF channel 45 , NBC and This Tv.
WSPA-TV - VHF channel 7 , CBS and Me-TV.
__________________________________________________
Here are some strong and sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html if using a eave mount - use the 4560. , http://www.ronard.com/ychim.html , http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
Install the HD7082P antenna above the roof in such a manner that the roof and house are not blocking reception in the directions of , south west , south , south east.
As always trees and tree leaves do a real fine job of reducing or blocking Digital Broadcast Tv reception and so do buildings and other obstructions including your own house.
It is best to install the HD7082P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions including your own house.
The Tv/s Must channel scan for the Broadcast Tv channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissaions travel through the air from the transmitting antenna to the receiving antenna.
