Old 18-Dec-2012, 7:31 PM   #11
With the correct diplexer, satellite and OTA can share a common coax.
Some can, some cannot.
In the "cannot" column would be just about anything HD from Directv after the H/HR-20 due to overlapping frequencies. Those are the systems that use the BBC, whether internal or external. SWM installs also cannot use diplexers. Older D* systems that used the Slimline 3 and older dishes worked fine with diplexers but those systems are not as common anymore. as the penetration rate of the HD systems improves.
Dish, I don't know about. Perhaps someone knowledgeable can provide such details.
