Old 18-Dec-2012, 6:54 PM   #2
I recommend 2 antennas.
_______________________
Antenna system #1.
For reception of the Canada Digital Tv stations/channels aim a Winegard HD7696P antenna at about 250 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes.com/antenna/pointing.html.
Install the HD7696P antenna in such a manner that the roof or house is not blocking reception to the south west.
_________________________________
Antenna system #2.
For reception of the USA Digital Tv stations install a Channel Master CM4228HD antenna aimed at about 165 degree magnetic compass direction.
Install the CM4228HD antenna in such a manner that the roof and house are not blocking reception to the south east.
__________________________________
Install the HD7696P antenna on the bottom and the CM4228HD on top separated by about 3 feet.
Antenna systems 1 and 2 are Separate antenna systems and will not be connected on one coax.
2 Separate coaxes will go to the location of the Tv and connect to a Remote control A/B antenna coax switch. http://www.mcmelectronics.com , 32-4425.
Saveandreplay has the same Remote control A/B antenna coax switch.
A/B antenna switching is Channel Surfing Friendly , press the button on the hand held remote control . change antennas and Keep On Channel Surfing.
Here are some places to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.amazon.ca , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.channelmasterstore.com.
__________
As always , trees and tree leaves do a real fine job of reducing or blocking Digital Tv reception and so do buildings and other obstructions including your own house.
It is best to install antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
The Tv Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Digital Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
_________________________________________
Falling off the roof is very close to zero fun , do not do it.
_____________________________________________________
I see the bus station and the high rises on google maps.
Make sure you can return the CM4228HD.
