Old 18-Dec-2012, 5:11 PM   #1
GoingToFall
Looking for some orientation help in Toronto
Thanks in advance for any assistance you can provide. I have had all my parts for a while now and I’m just about to finally make the push to get it installed.
After some research, I ended up picking up a Channel Master 4221HD. I am planning on installing it on the chimney of my two story house in Toronto.
TVFool Link: http://www.tvfool.com/?option=com_wr...cc49ac971e0c60
Since the installation will be tricky (height), I was looking for some guidance on where to point the antenna before I climb up there.
Setup: Channel Master 4221HD. The cable will go directly to the TV (with the only breaks being at the grouding block, and the wall jack). No splitters or distribution. Total length: ~45/50’ (?).
Channels I would like to get: I would like to get the US channels out of Buffalo (NBC, CBS, PBS, ABC, and FOX) but also the Canadian channels off the CN Tower.
The issue: I have created the image below. It shows my home at the center, the trajectory of the Toronto stations and Buffalo stations and the location of several high rise apartment buildings (~22 stories) and the approximate distances from my house. You can see that the Buffalo trajectory intersects the buildings.
Thanks!
GoingToFall is offline   Reply With Quote
