Thread: Antenna Advice
Old 16-Dec-2012, 5:38 PM   #8
As a test move the Tv so as to connect to the RG-6 without the 4 foot section of coax.
Look inside the connectors on the ends of the coax , look to see if the foil shield and shield wires are pushed in toward the center wire.
If so , push the foil shield and shield wires away from the center wire.
Replace the antenna to coax matching transformer with a new matching transformer.
