Old 16-Dec-2012, 3:44 PM   #20
samwynterhall
Rabbit,
Okay, so I've looked at the 3412, and also, the 3414 Distribution Amplifiers, and I've saved the info for next year, excellent recommendation. I've also actually thought about buying another antenna and having two TVs per antenna with possibly no amps required, but haven't research enough to know if they'd interfere with each other, but regardless, the distribution amp looks like a really good option.
As for grounding the antenna, when i get a chance, I believe I saw a copper wire running up there, so I'll definitely tie the antenna to it.
Again thanks,
Regards,
Phil
samwynterhall is offline   Reply With Quote
