Problem
Problem:
So I install the HD7000R with 70' of quad shield coax from SolidSignal and I get "No Signal".
Using Rabbit Ears I get about 25+ channels ...most of them quite clear. (However the Rabbit Ears do have a little built-in amplifier).
The actual setup is: The 70' cable is connected directly to the the Matching Transformer on the antenna. Then to get to my TV for testing I had to connect another 4' cable (using a female-to-female connector). Then I scan for channels exactly as I did with the rabbit ears and there is no signal (so I reconnected the rabbit ears and re-ran the scan for them).
What do I do now?
-Patrick
