Old 14-Dec-2012, 6:28 PM   #1
I8AZuk
Indoor antenna not cutting it: how does this one look?
First, my apologies to those of you that also monitor the DTV USA Forums...I posted this same question there first while waiting for my TVFool account to get validated.
I have what would seem like easy requirements given my location: TVFool.
I'm specifically interested in the following stations, all of which are at 297*: KTVK (IND), KPHO (CBS), KAET (PBS), KSAZ (FOX), KPNX (NBC), and KNXV (ABC). The antenna will be connected to a SiliconDust HDHomerun Dual (ATSC) receiver feeding multiple HTPCs.
Based on the tvfool data I've tried getting an RCA 1650 to pick up the channels I want, but I suspect that the chicken wire in the stucco walls is causing problems. However, even with the antenna behind a WNW-facing window I still get a lot of dropped audio and pixelation for several stations. I've tried this antenna both with the amplifier and without (still connected but unplugged) - it made some difference, but I still get dropouts. My house may indeed be in the shadow of the house across the street - I'm not sure if that really plays a part in reception at such close range.
I'm now looking at an outside eave location with almost clear LOS to the transmitters at 297*. I believe putting something like an RCA ANT751R at that spot (20' high) will provide better reception. Ideally I'd prefer to join the coax from the new antenna with a line that was previously run between the attic and a structured wiring cabinet. It's at this wiring cabinet where I'd connect the HDHomerun receiver to the antenna and to the home LAN.
My questions:
1) Is this a reasonable antenna for my needs, given my location? Too little? Too much?
2) If I'm on the right track for the antenna, are there comparable alternatives I should look at?
3) Is there a practical limit on the length of RG6 between the antenna and the receiver? Am I likely to need an amplifier in my ideal setup, in which there would be about 75' -80' of cable between the two, with one junction (a union - not a splitter)?
4) If an amplifier is necessary, can it go at the end of the run just before the receiver? Or do I need to get it closer to the antenna?
Thanks in advance for all your help!
I8AZuk is offline   Reply With Quote
