Thread: Antenna Advice
Old 14-Dec-2012, 5:37 PM   #2
Old tvfool report using provided coordinates.
http://www.tvfool.com/?option=com_wr...cc49db753d6690.
_____
The following recommendation is updated to reflect the new tvfool report below.
For reception of the Canada Digital Tv stations/channels and USA Digital PBS.
Install a Antennas Direct - Clear Stream 2 UHF/VHF , http://www.antennasdirect.com/store/...VHF-Combo.html , antenna with a Antennas Direct CPA-19 preamp aimed at about 140 degree magnetic compass direction.
Remove the Reflector Screen from the CS2V antenna and the CS2V will receive 2 directions , the Canada and USA Digital Tv stations/channels.
The CS2V antenna will be installed above the roof in such a manner that the roof and building are not blocking reception to the , south east , north west.
Some common antenna mounts are , tripod antenna mount , eave antenna mount , chimney antenna mount.
Here are some places to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.amazon.ca , http://www.amazon.com , http://www.winegarddirect.com.
_____________________________
Buy the HFS splitters at , http://www.solidsignal.com or http://www.hollandelectronics.com
______
As always , trees and tree leaves do a real fine job of reducing or blocking Digital Tv reception and so do buildings and other obstructions including the Condo building.
It is best to install antenna/s at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including the Condo building.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup nenu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
