Old 14-Dec-2012, 3:46 PM   #7
If the HBU55 aimed for both directions does not work.
Then aim the HBU55 at Green Bay.
Then install a Winegard HD7084P antenna aimed at about 192 degree magnetic compass direction.
Install a Winegard AP8700 preamp with the HD7084P antenna.
Buy the HFS splitters at , http://www.solidsignal.com or http://www.hollandelectronics.com.
___________
The 2 antenna Systems Will Not be connected together on to one coax.
The 2 antenna systems are Separate all the way to the locations of the Tv/s.
A Remote Control A/B antenna coax switch is connected to the separate antenna system coaxes at each Tv location.
http://www.radioshack.com , #15-1968 . or http://www.mcmelectronics.com #32-4425 .
A/B antenna coax switching is Channel Surfing Friendly , push the button on the hand held remote control , Change Antennas And Keep On Channel Surfing.
____________
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
