Got the FMSS installed, seems to be picking up some good signals with it being installed in the attic, I would think it would get better on a mast outside.. Couple other questions though...
1. Is it alright to add another coax converter directly off of the antenna to run an additional line to a different location rather then using a splitter on the one line ?
2.With it being an omnidirectional would it make much of a difference if it was turned 45/90 deg either way , with one arm pointing in a higher signal area ?
3.Is there a inline meter out there that can measure db from signals in range ? And not only with the FM antenna but usable with a UHF/VHF TV signals as well ?
