Okay, I'm done until next year about this time. The Antennas Direct DB4E in the attic works nicely for 13 channels (6 stations) and most have 4 out of 6 bars. I won't be able tell about tree inference until the spring, but for now, it's wonderful.
Final thoughts: I have to say, the size of the DB4e, about 3'x2', will make it extremely easy to move if the trees in the northeast corner of our lot interferes with the reception in the spring. Also, when I add the other TVs next year, I wonder if, instead of a pre-amp which installs on the mast, maybe getting an amp near each TV would be better so I won't have to worry about the attic heat on the pre-amp.
One last thing, do I need to ground an attic antenna?
Anyhow, thanks for all the help.
