Thread: Wrong Antenna?
Old 14-Dec-2012, 4:35 AM   #3
The current receivable Digital Tv stations/channels at your location are all UHF channels.
The current UHF band channels are 14 thru 51.
There are no current receivable Digital VHF high band channels of 7 thru 13 at your location.
There are no current receivable Digital VHF low band channels of 2 thru 6 at your location.
The tvfool channel list , lists the Real Digital channels that are transmitted and received.
And the (Virt) = Virtual numbers.
___________
Aim a Antennas Direct Clear Stream 4 UHF antenna at about 170 degree magnetic compass direction.
Install the antenna above the roof in such a manner that the roof or house is not blocking reception to the , south west , south , south east.
As always , trees and tree leaves do a real fine job of reducing or blocking Digital Tv reception and so do buildings and other obstructions including your own house.
It is best to install the Clear Stream 4 antenna at a location that has little obstructions to no obstructions of any type or kind in the directions of reception including your own house.
_________________
_____________________________________________________
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Digital tuners can develop - Digital Glitches - that are not cleared out with a simple channel scan.
Do Double Channel Scan.
