Thread: Wrong Antenna?
Old 14-Dec-2012, 1:17 AM   #1
kg105000
Wrong Antenna?
My channels range from 144 to 184 degrees and are 12 to 22 miles away. The weakest one is at 184 and is 30 NM. Four are clustered from 144 to 147 and have 56 to 67 NM and one is 169 degrees with 52.4 NM. I put up on the roof a RCA ANT 751 aimed at roughly 172 last year and had a few problems with the station at 184 degrees. However, after I increased the antenna height to 25 feet above ground I was getting all the channels.
After a hail storm destroyed the antenna last summer I bought another RCA ANT751 and put it up on the roof, but found I had to have it aimed at about 175 to ensure I got the 184 degree station. Now I’m having - random - problems getting channel 30 (144 degrees), channel 4 (147) and channel 9 (169 degrees) – but I always get strong signals from channel 5 and channel 11 (both at 147). If I move the antenna to 168 degrees I get strong signals on everything but I mostly lose the 184 station.
I want to get all the stations – do I need a different antenna or (heaven forbid) two antennas?
http://www.tvfool.com/?option=com_wr...cc49b6b928ce48
kg105000 is offline   Reply With Quote
