That's a near textbook installation, very neat, good looking.
The only thing I see that may deserve attention is the coax as it enters the siding. The coax should be run below the hole, then up to enter the hole. This will keep rain water from running down the coax and possibly into the wall through the hole. Calking the hole is an equally important step that will help keep the wall cavity dry.
How long is the cable (looks like #4 AWG) from the inter-system bonding device to the ground rod?
Thanks for the excellent post!
Reason: added question
