Thread: Need Help!
Old 13-Dec-2012, 10:03 PM   #3
Is this a , house , town home , condo , apartment , mobile home , motor home , or etc.??
What directions do the windows face??
What directions are patios/balconies??
What floor??
What is the top floor??
The best for reception with a indoor antenna is , building construction , wood with wood or vinyl siding and composition single roof.
The following is a - non complete - list of building construction that will reduce or block Tv reception more.
Concrete , concrete blocks , bricks , big rocks , metal siding , metal roof , metal backed insulation , solar panels
What is the building construction??
__________________________________
--------> Antennas and Amplifiers DO NOT in any way shape or form "Pull In" Tv transmissions.<--------
Antennas and Amplifiers DO NOT Work Like a Vacuum Cleaner.
The metal reception elements of the antenna Do Not work like a hose of a vacuum cleaner.
The amplifier Does Not work like a vacuum motor.
_______________________________________________
The following is closer to the truth.
The Antenna - Receives - electromagnetic waves that arrive at the metal reception elements.
The Amplifier makes the signal , electromagnetic waves stronger.
