Old 13-Dec-2012, 8:32 PM   #1
jpdtv
Almost perfect in NJ - need final tweaks
Looking for suggestions on the following setup - my report is below;
http://www.tvfool.com/?option=com_wr...cc495ccfa8def3
I have two antennas split with a diplexer, one pointing to NY (93 compass) the other pointing to Philly (212 compass) both in the attic. The NY antenna is a AntennaDirect C2, the one pointing to Philly is a larger, older antenna from the previous house owners (looks like one of the Winegards but i cant find a model number anywhere). They are several feet apart, and there is about 15 feet of cable coming from each running into the diplexer, which then feeds right into an RCA preamp before continuing through the house to one test TV. I have the preamp power plug linked into the line about 6 feet from the TV.
I'm getting about 30 channels, mostly NY which is what I want all with 90% or higher signal. I'd like to pick up one or two more but not a big deal. I'm not getting many Philly stations but I'm going to try to keep calibrating the aim. A few questions I was hoping some of you could clarify:
- The preamp power - does this matter where in the line once in the house it is added?
- I noticed the diplexer I bought says its for antenna/cable and satellite combining... does that matter? The philly antenna is running through the SAT input and the NY antenna is running through the CAB/ANT input.
- Once I start splitting off to additional TVs, should I add a amplifier somewhere at the first split?
Thanks for all your help this site is great!!!!
jpdtv is offline   Reply With Quote
