Old 13-Dec-2012, 6:45 PM   #2
Attics Are Not a reception friendly environment and Never Will be a reception friendly environment.
The metal backed Radiant Barrier will cause reception issues , reflected signals bouncing around in the attic , multipath.
Yes you can try the ANT751 in the attic aimed at about 202 degree magnetic compass direction.
Yes remove the Radiant Barrier and get the ANT751 antenna close and aimed through the hole.
I recommend try reception without the preamplifier.
The preamplifier will amplify the reflected signals bouncing around in the attic off the metal backed insulation and can make reception worse.
WPXA-DT UHF Digital channel 51 is the odd one out , because of the direction of the transmitter , and will most likely will not be received in the attic.
The metal backed radiant barrier will most likely block the signal.
